1 - 3 of 3 Posts
Hello.
If anyone can help me with the tool length required to set the shims on my gl1200 lifters I would be thankful.
I have searched with no avail.
Tim
You mean the generic type? I have one that is only 9" long and it will do many engines with shims. In hindsight a longer one would give better leverage, but mine works.
Thanks for the reply Larry.
We may be talking about 2 different things.I am needing to check the lifter preload,the actual Honda tool is about 2" long and fit's where the lifter goes,then a measurement is taken and shims under the retaining bolt are added or removed as required.
I found some info on another forum,but I want to verify it.
Tim
1 - 3 of 3 Posts
