1 - 14 of 14 Posts
1985 GL1200 LTD
I have no resistance whatsoever on my suspension. Talk to me about where to start on this. The back is probably the most noticeable. Nearly every bump means bottoming out. Front is just as bad really.
I've seen some things about replacing the fork seals up front, but I'm not finding much about the rear, or how the air suspension works with all of it.
  • Like
Reactions: Donty
1985 GL1200 LTD
1985 GL1200 Limited Edition
For the front I put a set of Progressive springs as it was easier than rebuilding the forks. The rear holds air for a few hours so I was just airing the rear using the Auto Level. Right now my compressor doesn't work, switches gummed up I believe, so I air the rear shocks using the reed valve located near the top of the right rear shock... Until I get time to repair it!!
There are a lot of spring compressor tools hanging on nails in garages across North America. Let us know where you are and we can send you one to use.
1987 GL1200 Interstate
I believe those bikes have a place on the right side where you can use a regular air compressor to fill them.
1985 GL1200 LTD
Discussion Starter · #8 ·
that would be fantastic.
yessir. Found both today. Seems like the rear isn’t holding. Front seems ok for now. Haven’t ridden anywhere. Just a few “plops” with my big ass in the driveway. Gauge still reads dashes for now. I’m sure that’s one of many gremlins I need to chase on her
1985 GL1200 LTD
Discussion Starter · #10 ·
Rear problem may be a simple as a leaky hose. Take the seat off and look around.
Alright. Most likely scenario honestly. I feel like some owner at some point left this bike outside 100% of the time. I'm betting I'll need to replace a lot of rubber on this thing.
1985 GL1200 LTD
Discussion Starter · #12 · (Edited)
the compressor doesn't come on AND there's a leak. Fuses are all good. Did an eyeball check and quick resistance check on all of them to be sure. There are 2 bundles of cut wires on the bike that I need to get around to at some point. Maybe the electricity is somewhere in those bundles.
Haha well the compressor doesn't come on AND there's a leak. Fuses are all good. Did an eyeball check and quick resistance check on all of them to be sure. There are 2 bundles of cut wires on the bike that I need to get around to at some point. Maybe the electricity is somewhere in those bundles.
Would be a good place to start.
Piaggio MP3, was 02 GL1800
please use a filament bulb " Tester with needle nose probe " instead of an Ohmmeter, which is notoriously invalid for "Continuity Tests"
you need a "tool" that pulls an appreciable amount of Amperage to test for Continuity.
Ohms is useless, a badly corroded fuse/connection will show "good" with an Ohmmeter and lead to false conclusions.
1 - 14 of 14 Posts
