1985 GL1200 LTD
I still have this bike torn down while awaiting my o-rings and I've been thinking about these bolts on the tensioner pulleys. The manuals say to tighten them just enough to where it can still have free movement. I feel like these springs don't really provide enough pull to keep the timing belts tight enough honestly. As many of us, I referenced the Steve video when changing my belts and I swear it looks like he's putting some decent gorilla torque on those bolts.
What's the general consensus here? Leave the free play or tighten? With mine tightened all the way up, I do have appropriate slack, although I'm aware that not allowing the pulley to move may cause pressure to the bearing.
1988 Honda GL1500
You only have the play when tensioning the belts, when done you tighten them up
1993 gl1500, 1976 gl1000
Tighten bolts to 19ft lbs when finished adjusting.
I think you didn't read far enough. That is for installation of the belts, not the final procedure.
1985 GL1200 LTD
Thanks all. Easy enough.
