Put back #15 both sides, not all the way in, just 3 or 4 turns, just to release the weight of the eaxhaust system on the pipes.
Take out the fairing lowers.
Take out the engine guards.
Now you can remove #13 on the bike bandit diagram (8 nuts) If the stud comes out instead of just the nut, don't worry, it's all good (as long as it doesn't snap)
THEN the front will be able to drop. If the tail of the muffler hits the saddlebags, put something under the exhaust pipes, so they don't drop that far, and remove #15, which will drop the whole thing.
OR do one side at a time (which I wouldn't do) by removing 4 nuts, spinning pulling on the pipe until it comes off, replacing the graphite seal between the pipes and the muffler, with the mufler IN SITE.
I prefer to remove the muffler and pipes. Clean everything with a wire brush Removing all rust encrustation (plumber wire brush is great for the muffler side) Widden the clamp gaps with a large screw driver(no more than necessary). Make sure everything fits outside before mounting it on the bike.
When pulling out or pushing in the pipe in the muffler, spin it back and forth avoiding to "bend" the connection otherwise you will damage the graphite seal.
To put it back together, same thing, start by "balancing the muffler on #15 (both).
Carefully spin & push the pipes, one side at a time, once they are all the way in, line them up with the head exhaust holes. Put just one nut (#13) on each side with only 3 or 4 turns, because you might have to release the pipes a bit to get the engine guards in (specyally the left one with the starter and the shifter right there. The right one goes in easily if you spin it clock wise 90 degrees while geting it in.
Torque #13 first at 13 ft/lbs If you re-use your copper gaskets, try to put them in the same location/orientation where they came from.
Now that the pipes are torqued back in, with the muffler in place, try to lift the joint where the clamp is, just to get rid of the slack. When the pipe is all the way in the muffler seal, it is very strong, you won't brake it, plus the pipe side isn't going anywhere beacuse it's already "fixed" to the head. While lifting the joint torque down the clamps, alternating between the two bolts on the same side. Torque them down to 16 ft/lbs (#14 on bike bandit's diagrams), again going back and forth untill they both "click" your torque wrench at 16 ft/lbs.
Install your engine guards torquing the lower (side to side thread) at 43 ft/lbs. Lower front at 25 ft/lbs and the upper U-clamps at 9 ft/lbs.
#15 torque is 30 ft/lbs and you're almost done except for the lower fairings. I wouldn't install the lowers: Take her for a now quiet spin. Sinc those carbs, and now go for a quiet and smooth ride. THEN install the lowers.
This is how I do it (no guarantees implied), and the advise you are getting is worth what you are paying for it. But if it helps you, please donate to keep this place running.
