When I went to start my bike today I have no power at all. My battery has a full chargewith 12 V and I checked all my wiring connections...all look good. My main fuse is new. I am at a loss of what the problem could be.
Any Thoughts......?
You could check to see if you have voltage at the red wire on the 8 pin connector on the right inner side of the fairing.
Voltage NO = main fuse or wiring from solenoid plug
Voltage YES = Ignition switch iffy
You may want to clean all wiring connections at battery and then re-tighten connections. I have had issues like that in the past it doesn't seem to take much to jar something loose.
Frank,
What fuse are you speaking of? The dog-bone one at the starter relay? Did you replace it? Do you mean that you turned the ignition switch on and nothing came on, even the lights?
Bobbydsp
Took it to the shop today and it was the starter relay.
Robert....The other day when I turn the key I had no power...not even lights. I did replace the dog bone fuse.
Yeah, Frank. I did not replace the relay but did get a new one which you had, I think. Glad you got it fixed.
Robert
the relay itself was not bad,but was the added on area where the dogbone attaches,which also creates a problem when the connector gets corrosion or a loose connection
making this upgrade in addition to hardwiring the stator connector and the rectifier will give you alot of trouble give
years of riding
http://gl1200goldwings.com/techcenter/article1004.htm
but its just my opinion on upgrades since alot of people seem to never have had problems,but sooner or later....lol
Franks' bike has an exterior alternator.
Bobbydsp
