I noticed yesterday when I started home from work that the ole girl blew a lot of smoke when I started her up. Figured due to being parked on the side stand. but this morning she smoked alot again and continued for 5 minutes. so I just shut her down and figured I would ask some questions.
51K miles on the engine, has been sitting for a while. I am thinking maybe a stuck oil wiper ring or is there something else that may be causing this problem.
Any ideas or suggestions?
:thumbsup::thumbsdown::waiting::?:?:?:?:?
start running sea foam gas and oil. should clean up a bit. oil smoke from the left shows valve guides or rings. compression check the cylinders. A touch of smoke as I understand is normal. mine sat for eight years and smoked alot...did sea-foam and changed oil four times at 500 mile distance's cleaned right on up and raised my compression as well... I like the minimal approach and do not panic.
The four cylinder Wings tend to smoke for a few minutes on start upwhen left parked on the side stand for a while. 51K should not be any reason for smoke. The age may cause the valve guide seals to harden an allow a little oil into the combustion chamber. Go for a ride, say 100 miles or so. That will go along way to getting the problem straightened out.
I like these answers, I will throw some seafoam in tonight and run her tomarrow for a couple of hundred miles, change the oil. and on sunday do it again. I got a free weekend and can finally put some mile her.
would mystery oil do?
Would synthectic oil hurt her?
It is probably valve stem seals. The smoke usually clears after a couple of miles, much quicker than leaving it ticking over on the stand.
there has been some thought, that synthetic oil can cause some seals to leak, I'm running a semi synthetic, with a ester base at the moment, and have had no leakage problems,after two oil changes.
marlin_1
just a thought check your oil if its over full you might have a float sticking ben down that road your gas milage might help you also to compare consumption
I had read somewhere, may have been on here, that when puffs of smoke develop, they (the poster) switched to 20-50 from 10-40 and it stopped the smoking. Before I did my oil change, it would smoke a little when I started the bike, only for a second. I switched to 20-50 when I changed the oil and not once has it smoked. So during the warmer months, I will run 20-50 since I have had good luck with it, then switch to 10-40 during the colder months to see if it goes back to smoking on start up. Don't know if this is the cure for everyone, I just know it worked for the original poster, and it worked for me.
some guys say the synthetic makes the clutches slip may want to rethink that one
:waving:
Hey Fellow Submariner,
Try some Super Tech Walmart 15 w 40 motor oil in the bike for a few thousand miles.
It seems to swell oil seals better than some oils.
It may help the smoking problem, worth a try and it is good oil.
I rode FBM subs back in the 1970's
See Ya.
