Blown starter solenoid? (the thing the dogbone fuse is attached to)
Try disconnecting it and bypassing it.
In your case you need to be checking voltage right at the battery itself (dont know where your meter is wired up)When I turn the key to 'Acc.' I get lights on the added on voltmeter, and some dash lights. Voltmeter reading around 2-5. Turn key to 'on' and press 'Start' and there are faint lights on the dash, but almost nothing.
-Shawn
Yeah that, have it checked so you can really rule that out and not be guessing. Check all connections, ditch the dogbone, you can't tell if they are good just by looking.Batteries can go bad anytime. 1 year, 1 month or 1 day if they want.
Everything should be suspect.
