The way I understand my manual, the pulse generators take care of the spark advance. When I twist my throttle more than about a quarter of turn, the bike starts bucking and I lose power, it doesn't backfire, it just acts like it is running out of gas.
I have,......................
changed fuel filter, flow tested the electric fuel pump, drained the tank, checked coil resistance and plug wires, replaced suspicious vacuum lines, changed the plugs, pulled the carbs and cleaned all jets, replaced fuel lines. Today my son and I checked the plug from the pulse generators and the book calls for a range of 1100 to 1300, when we checked each of the leads we are seeing right at 200. Because we are readinglower than the manual states, could that be my problem? Could I just not be advancing the spark enough. Earlier in a post someone told me to ignore the pulse generators that they either work or they don't, I'm beginning to think that is not the case? I hate to lay out the $80 if that is not the problem. I am almost to the end of troubleshooting and I have not found anything that I have done to make a difference in how the bike runs.
It will start quickly and throttle up with no problems in neutral. Idles perfectly, but when on the road, you get to third gear and rotate the throttle, it starts bucking and hesitating badly, I can keep it cranked and it will eventaully gain rpm, but it is not happy.
