I can't buy a new radiator as it is discontinued. What do I need to do to fix one of these 2 radiators I have.
I don't read that it's overheating, only that it runs hot.Bike starts getting hot after about 10-15 miles as soon as I get in town temp goes up. Fan works, Pump works.
If it were just an indication problem, the cooling fans would cycle normally. You say they come on and stay on. If that's the case, then the thermo switch AND the gauge are faulty?Great ideas ya'll. I don't have an infrared sensor but she feels hot to me when I stop. Hose seemed stiff enough when I took it off to change thermostat and change timing belts.
What's the difference between flow test and boiling out? What kind of flow is good?If it were just an indication problem, the cooling fans would cycle normally. You say they come on and stay on. If that's the case, then the thermo switch AND the gauge are faulty?
If it reads hot, and the fans stay on, then it is hot.
Take your stand-by radiator to a radiator shop and have it FLOW tested. Then install it.
