1 - 3 of 3 Posts
Hi,
I ordered from ebay a set of rear brake seals
http://www.ebay.co.uk/itm/ws/eBayISAPI.dll?ViewItem&item=200648712054
When I've come to fit the seals it turns out they are to small - the seals are for a piston with an OD of 27MM rather than the almost 32MM OD of my rear brake pistons.
Anyone aware of any reason why they would have sent seals with 27mm OD- is it something to do with one of the front brakes having smaller pistons because of the unified braking system - would 27MM seals fit that brake?
Thanks Terry
Senior Guru
http://www.hdlparts.com/default.asp
You need to be carefull buying stuff like that off ebay especialy not original parts his listing is wrong for starters as he has them for 84/88 and the photo listed is not the seals your buying the 1200 finished in 87 i cant help you with the size on the link is the parts fiche but says nothing about the it except front and rear are the same part nos
Junior Grue
The 27mm seals fit the right front caliper just as you suspected.
Both the left front and rear have 32mm pistons.
The parts book for the front calipers is a little confusing as it lists two different seals but doesn't tell you which side they're for.
1 - 3 of 3 Posts
