Ok, this is probably normal, I have heard other shaft drive bikes make this noise, I just want to make sure before I put all the plastic back. I have the rear end all back together, everything coated in moly paste, tire balanced, 80/90 gear oil in the final drive, shocks back on, pretty much everything but the rear caliper. All the splines were in great shape, the bearings felt fine by hand, and made no noise when I spun the wheel on the axle about 100 times while balancing it. After getting it all back together, I started it up on the centerstand and put it in first. I an hearing a rattling sound from the rear end when the wheel turns in gear. It sounds like a drum brake hub with a few rocks in it. I figure it is just noise from the lash in the drive system. With the engine off, and in neutral, it sounds fine when you spin the wheel by hand. I never paid any attention to it before I took it apart, so I have nothing to compare it to.
Does this sound like a normal noise? About the only other thing I could do would be to replace the wheel bearings, and I'm pretty sure they are fine. I have not ridden the bike yet.
