· Junior Grue
If you're asking about the two identical spacers on the left side of the wheel they go on each side of the caliper bracket with the flange facing the bracket.
· Registered
If you're asking about the two identical spacers on the left side of the wheel they go on each side of caliper bracket with the flange facing the bracket.
Thanks a bunch! Pulled the wheel a few days ago and didn't see one of these drop. Moved the block from under the wheel and there it was on the floor. The dreaded where the hell did that come from part.
Check and see if your spacers are identical. For my interest. Most I've seen are the same, but I came up with a shorter spacer while cleaning up the garage and I couldn't figure out which side it went on. Turns out, it wasn't for that bike, but I'd hate to find out something was out of alignment because one spacer was thinner than the other.
