Hey Guys,
I'm kind of stumped on this one. My GL1200's right (like you're sitting on the bike) front brake caliper appears to be leaking on the bottom side/piston. The fluid for certain isn't coming from the fork or bleeder screw. It's only been about 300 miles since I rebuilt/resealed the front and rear calipers. That was in the spring. Could warped rotors cause a caliper to leak? I knew the rotors were warped, but I was hoping to hold off a while until I got time to replace the rotors with a used rotor set I got off Ebay. I believe the pistons were in good condition and not rusty when I rebuild the calipers. Another question: Do you think it's okay to replace just the piston seals and not the dust seals? Thanks.
Hey Guys,
