1 - 3 of 3 Posts
Hi
Looking to sync the throttle bodies on my SEI, and am aware they can only be done side to side. Ive changed out all the vacuum pipes and the bike idles ok n revs well. From what ive read in the manual the screw to balance the sides is under the right [as you sit on the bike] CFI cover. It appears this is the only screw apart from engine idle i will need to touch. I have vacuum gauges does anyone have any tips before i start?
Piaggio MP3, was 02 GL1800
Page 3-5 talks about Throttle Valve Sync in the 1985L Svc Supplement, should be similar to your bike.
Also, if you click on your Avatar, top right corner of this page, then click on Conversations,
there is a link to more info for you.
1 - 3 of 3 Posts
