1 - 3 of 3 Posts
i am still having the shutting down issue with my 1985 aspy,i have taken apart the ignition switch,and cleaned the ground,it seems it only happens when i pull in the clutch to come to a stop,wiggle the key and try to move the ground does not work,when this happens everything shuts off including the clock,any ideas:praying: thanks
"Still having trouble", I assume you have posted this before. What suggestions did you get, hate to rehash old replies. Best if you reply to the original thread so that won't be an issue.
Since there is no ground for the ignition switch, and the clock isn't wired through it, I suggest you look more toward a battery/main fuse/cable connection.
1 - 3 of 3 Posts
