1 - 11 of 11 Posts
Junior Grue
You can keep an eye on ebay or other sites like it but I doubt you'll find any.
There are companies that make generic rings by size, compression rings from them should be obtainable, oil rings might be more of a problem.
Does anyone know what the measurements are for the rings, I found these Hastings Rings that are for a 2.972 Bore
Ring Size & Type
Top 2nd 3rd Part # No. Cyl.
Groove Groove Groove
1.2 398 1.5 126 3.0 054 2C4668 4
732
1.5 032 1.5 126 3.0 996 4782 4
732
1.5 363 1.5 126 3.0 996 2C4782 4
732
1.5 032 1.5 126 3.0 872 4863 4
732
1.5 363 1.5 126 3.0 872 2C4863 4
732
1.2 398 1.2 610 2.5 934 2C5184 4
732
1.5 032 1.5 126 4.0 058 5716 4
732
1.5 363 1.5 126 4.0 058 2C5716 4
732
1.5 327 1.5 126 4.0 058 2M5716 4
732
They also show one set for a 2.973 Bore
1.2 398 1.5 126 2.8 996 2C4884 4
732
Hoping something like this will work Any Thoughts?
Junior Grue
You've never told us why and if you have the engine apart.:?
The only spec's I could find
Piston ring Standard service limit
End gap Top and second 0.10-0.30 {0.004-0.012} 0.60 (0.024)
Oil ring side rail 0.20 0.90 (0.008 0.035) 1.10 (0.043)
Ring·to-ring land clearance 0.015 0.045 (0.0006 0.0018) 0.12 (0.005)
Your best bet is to carefully measure what you have and try to match it. The height is critical as is the thickness (difference between ID and OD)
You could try to contact the ring manufacture and give them the piston dimensions and see what they say.
Steve
Discussion Starter #11
Well I spent a couple of hours over the weekend and sent measages to the various ring manufacturers. Hastings got back to me and said thier 2C5184 for a 2000-06 1493cc Eng. DC DOHC 1.5 Litre A5D Mazda Eng. w/2.5mm oil grv should work. I found them on-line for $78 for a set of 4.
I'll let you guys know how they work out.
1 - 11 of 11 Posts
