I had a similar issue with my 1100. I somehow munched up the shaft spline. I took the gear out of the housing and cleaned it up. I found the spot where it would slip on.I lined up the sweet spot, and put it all back together. I had to slightly turn the shaft ,with my fingers then tried it several times until it matched up.I know it makes you nutz when the installation is the longest part of the job.,,
