....so we made a decent tool from a 30mm socket to adjust the steering bearing nut on my gl1500. After a couple hours grinding we had a good fit and it worked fine. So we tried it on my buds gl1200 and it also fit just fine but his 1200 only had one nut under the rubber cap. No lock washer and lock nut. We did the fork resistance test using a digital scale from side to side and it was a bit out of range on one side but not terribly(wing world archives). We concluded he could ride a bit longer but at 80,000 go ahead and order new bearings. SO I am still thinking about that single nut holding the entire triple tree together with no lock washer above it. Is this normal for a 1986 gl1200? Also there was not enough room on the stem for another nut. Could some of you 1200 gurus let me know how this thing is supposed to look? This buddy is 70 years old and a bit forgetful and I don't want him riding anything unsafe.Thanks a bunch!
