1 - 3 of 3 Posts
Hello,
What a great site...I was hoping someone might have an answer to my problem.
I'm in the middle of replacing a bad set of bearings. The old tapered roller bearings came right out. The problem is the outer races...both the top and bottom races are really jammed in there. Using a drift and quite a bit of force with the hammer just is not moving them.
Any other ways to remove these races?
Thanks for the help
God Bless:cooler:
Piled Higher and Deeper
Welcome to the site!! but sorry that I cannot help you with the bearings.... SDB/Jim
As you can see of course there is a tool available but I cant see why your having so much of a problem.
It could be your applying too much force in one place and jamming the race into the seat.
The top and bottom races are a different size and using the tool, the top race is removed first then the lower one.
Try using a little heat on the frame to expand it a little and try to drive the races out evenly all around
1 - 3 of 3 Posts
