I'm confused, does your 1200 not have a tach?
I'm confused, does your 1200 not have a tach?I need to adjust the carbs so I need a tachometer to set them with. autozone has one and it has two wires, the instructions tell how to hook to A coil on a car. what I don't know is how can I hook it to my 1200, I have four coils..:sadguy:
You're talking about adjusting the fuel/air mix, right? Unless your 1200 is modified you have TWO coils, and you don't need to hook to the coils. Out of the CDI is a solid yellow wire. Connect the tach to that and a ground. When I did my carbs last it turned out that my on-board tach was remarkably accurate. Go figure, it's only 28 years old!I need to adjust the carbs so I need a tachometer to set them with. autozone has one and it has two wires, the instructions tell how to hook to A coil on a car. what I don't know is how can I hook it to my 1200, I have four coils..:sadguy:
