GL1200 Thermostat
8982 Views 12 Replies 8 Participants Last post by  Shadowjack
Is there an aftermarket thermostat for a 1985 GL1200I?
1 - 13 of 13 Posts
And that tells us what for a GL1200 thermostat?
http://www.goldwingfacts.com/GoldwingTips.htm
Lists one thermostat for the GL1200
GL1200 Thermostat. Halford's, the UK car parts chain stock the HTK 648 thermostat which fits the GL1200. Thanks to Mark from Ashford in Kent for this tip.
I have no idea if there's an equivalent part available in North America.
Thermostat
  • NAPA #101
    Stant #13868
    Murray #3868
http://www.ngwclub.com/forum/viewtopic.php?f=24&t=7416
Timing Belts
GL1000 & GL1100
(requires 2)
  • Honda part #14400-371-04/14400-371-14
    Gates #T274
    NAPA #250274
    Goodyear Gatorback #40274 (AutoZone & ??)
GL1200 (requires 2)
  • NAPA #NBH 250070
    Gates - #5043 or #T070
    Goodyear - #40070
GL1500 (requires 2)
  • Gates - #T275
    NAPA - #250275
    Goodyear - #40275
Radiator Hoses
  • Napa #7733 ($16.95) does both top & bottom
    Gates - #21008 does both top & bottom
    AutoZone - #B70834 ($9.95) does both top & bottom
    (may need new screw clamps, my stock ones worked okay)
Radiator Cap -- Standard style with 13 Lbs pressure, any auto supply store
  • NAPA/Belkamp #703-1445 (2/27/13, new #703-1697) or STANT #10229
    Murray #7713
    In Canada, Benson Auto Parts, Stant #10229
Thermostat
  • NAPA #101
    Stant #13868
    Murray #3868
Oil Filter for GL1000 & GL1100
  • Honda Part #15410-426-010, 15410-422-004
    FRAM #CH6009 (comes with both o-rings, $4-$5 locally)
    Napa #PS4940
    Purolator #ML16809
    WIX #24940 (O'Reilly's)
Cam Seals Honda part #91209-371-003, Oil Seal (27X43X9)
  • Napa #ATM 2117994, Altrom
    Beck Arnley #052-2755, AutoZone
    Note: x3 on 1000s and x2 on GL1100s.
    Fel-Pro #TCS 45718 (comes with 2 seals per set)
Signal Flasher
  • NAPA #552 flasher relay, 2 pole
    Tridon EL12 at most autoparts stores ~$10 electronic flasher, stops slow/fast flashing. Try the 552 first.
Front Crank Oil Seal - GL1000 & GL1100
  • NAPA #13954 (35x55x8)
Rear Oil Seal for the clutch lever
  • NAPA #5410 Transeal, made by SKF 14x24x6
Valves, Intake/Exhaust Parts'n'More 10 and 15 bucks each respectively.
Spark Plugs - (1000, 1100, 1200) Stock is NGK D8ES.
  • D7EA or ND X22ES-U for cold climate
    D8EA or ND X24ES-U for standard operation
    D9EA or ND X27ES-U for extended high speed operation
Spark Plug Boots - NAPA part # NGW8072
Serviceable Fuel Filter from Spectre
  • O"Reilly's Auto Parts, p/n 6932, about $10
    Hall's Speedshop online
    chasdog says, "I wrapped a piece of rubber around it to protect it and keep it snug - works great and you can clean it AND replace the filter element ... YES the filter elements are very easy to find - (O'Reilly's) keep them in stock - 3 to a pack."
Copper Squash Gaskets (exhaust header) - (1000, 1100, 1200)
  • NAPA; Fel-Pro part number 60567 or 12-1002.
    The automotive applications are 1976-84 Honda 1.3, 1.5, 1.6 and 1.8 liter 4 cylinder engines. May also fit some 1991-95 Nissan 4 cylinders. $1.49 each. Thanks to sunnbobb in this thread.
Regulator/Rectifier from socrace
  • Shindengen part number FH008EB, from 04-07 CBR1000RR and CBR600RR.
    "This is a true series regulator, it does not work by shunting current like all [of Honda's] previous models." Get more info in this post by socrace.
Wheel Bearings - GL1000 & GL1100
  • Front - 6302 2RS (x2)
    Rear - Takes a 6204 2RS & a 6304 2RS
    Readily available from any bearing distributor.
Swing Arm Bearings - GL1100
  • P/N 30203, requires 2.
Front oil seal - 1200[/b]
  • Interchanges with the 1500. P/N 91201-MN5-003.
    Discontinued #91201-MG9-005. For 1200 / 1500 application;
    on the seal the #'s say; A 8 SD 35 59 8 L HS. Measures 35 x 59 X 8
Head Gasket Job, Part Numbers, our thanks to Alwing17 for these.
  • Qty - - - Part # - - - - - Description
    2 -- 12251-371-306 -- gasket, head
    2 -- 12328-371-000 -- gasket, cyl head cover
    2 -- 19429-371-306 -- gasket, water elbow
    2 -- 91308-371-003 -- o-ring, oil orifice(small)
    2 -- 91305-371-003 -- o-ring, oil orifice(large)
    4 -- 91301-MB6-003 -- o-ring, coolant tube
    4 -- 18291-386-306 -- gasket, exhaust
    4 -- 91301-371-005 -- o-ring, intake manifold
    1 -- 91256-096-651 -- seal, tach cable
    1 -- 12390-371-405 -- insulator, fuel pump housing
    3 -- 91209-371-003 -- seal, camshaft
    8 -- 12209-MB9-003 -- seal, valve guide
    ** And timing belts, oil, silicate-free coolant, as well as a thermostat. The cam seals and valve guide seals are needed if you choose to lap your valves while the heads are off.
Speedo/Tach Rubber Seals, Honda #37235-323-700 (fits 1000 and 1100)
  • Western Honda Part #5 on the fiche . . . $11.36 each
    CMS NL product #37235323700 . . . € 10.00 each
Thermostat
  • NAPA #101
    Stant #13868
    Murray #3868
What you're saying is that the GL1200 uses the same thermostat as the GL1100?:?
Thank you all for the quick and helpful replys. All great info that I've copied and pasted to my GL1200 folder.
The list should have the spark plug numbers changed, 1200 takes a dpr8ea plug, which is considerably different.
Teacher:
Is this a POP quiz?
Teacher:
Is this a POP quiz?
No. Why do you ask?:waving:
You da teacher! That's why I asked!
NAPA 703-1433
Stant 535080
Autozone 15868
According to the online parts fiche I use, there are 119 Honda models that use the same thermostat as a GL1200. Probably anything they ever made that was water-cooled, it looks like.
1 - 13 of 13 Posts
