:applause:i have a ticking noise on the right side
and gas smell when u let off the new guy:waving:
When u are rideing and let off u get a smell like old gas
Loyal member
That is an enriching curcuit that prevents backfire when closing the throttle,without it you would create a lean condition resulting in popping on compresion.
1987 GL1200 Interstate
From experience, the clicking is the fuel pump experiencing a dry condition. May be you have a partially plugged fuel filter. When was the last time you changed it?
The smell can be lots of things. Any little leak can be smelled more when you stop. Mine acted exactly as you are describing when a floatdidn't float any longer. Shortly after replacing that one,I started smelling it again and, again, it wasa float that didn't. At that point I replaced them all.
