You do not want the belts to be too tight and I understand that you also do not want them too loose. Use your finger to SLIGHTLY pull down the belt right next to the tensioner and tighten the tensioner as the spring moves the tensioner against the belt. When this is done, check the belt by measuring the freeplay in the middle of the long part of the belt. You should not have more than about a quarter inch ( 5 to 7 mm )of play in the belt but you should have some. Make sense? You just don't want them too tight. That will cause premature failure of your tensioner bearings. Make sure you check the tensioners pretty good that they don't have any play in bearings and they roll without slop or grinding.
