Yes it works good, I used lexan and I use a 25mm die on the threads to match the hole, you need to take those threads down to near nothing first and use athe die and make new threads, it's a 3/4 pvc adapter that I used...I used a 15/16" holesaw[special order] and drill press, and sand the edges with a 1" belt sander..a littleso itfits the hole tight, glue it in using pvc glue..nice tight fit so they are pressed in tight on a flat surface..and take an 1/8" off the length too Here's a photo...the oem hastwo lense's this only hs one..Sorry for stepping on your post here...
