· Registered
Need help.. I have been to all of the local bike shops (including AutoZone) looking for a replacement rear trunk turn signal bulb for my 1984 Goldwing Aspencade. I just bought the bike this spring, so I don't have a lot of history with it. The previous owner put a 12v 1.8w bulb on the right side. It's not bright enough, on the left side there is a 12v 6w bulb which is nice and bright. I assume the 12v 6w is the correct bulb. Does anyone out hear know where I can purchase the correct bulb? Thanks
I did find this post but does not lead me to where I can purchase just the bulb.
http://www.goldwingfacts.com/forums...orum/352392-1200-rear-trunk-turn-signals.html
It sounds like you have an aftermarket turn signal trunk kit. Can you post a picture of the 6w bulb you have? Someone will be able to ID it for you easier from a picture.
Autoparts store, get a pair of bulbs (12V 23W) type 1073 or compatible sized bulbs in clear or amber. Should cost you about $3.00 or less for the pair. These are the bulbs that originally came in the bike.
· Administrator
1987 GL1200 Interstate
As GasWing said, those are aftermarket bulbs so we have no reference numbers to help you with.
I think those kits are still sold through J.C. Whitney. Maybe they could tell you what bulbs the kit uses.
Good luck, and if you find a number, please come back here and post it. That way, maybe we can help the next guy who has this problem.
