Jum,
On my 80 GL1100 and 83 1100 Aspencade, it is the 3rd fuse from the right. If it isn't the fuse, then It is the turn signal plug underneath your false gas tank, on the left side, towards the front. Being an 82, it is probably out of the harness, and lying under the breather to the left, or close by. It is round, has 2 plugs, with an extra green wire coming out of it. Manually switch your blinkers, and you can hear it click. It can be repaired by cleaning, and black tape, (Will not last but around a year) but they are not all that expensive.
Good Luck, Nightrider1
Jum,
