All you need is new gaskets and required o-rings. No dope! Or you're asking for problems like plugged ports.:lash:I'm replacing water pump on a 1987 gl1200 do not want any leaks, Would it be ok to us a copper coat gasket compound on gaskets
Use a little vaseline to hold the o rings in place. I use a little "red" permatex high tach spray very stingily on the paper gasket.I'm replacing water pump on a 1987 gl1200 do not want any leaks, Would it be ok to us a copper coat gasket compound on gaskets
