Its about safety and common sense.. Rudy's 2/3 (66%) rule is a good one... I've seen regulations (one in this country but mostly in others) that limit the GVW of the loaded trailerranging from40% to 100% of the tow vehicle GVW and will sometimes allow/limit to 200% when trailer brakes arepresent.
California is a littlelenient in that it only limits motorcycle trailers to 1500 lb (wow!) and if you add brakes you can go higher.. a quote below
As with other lightweight towing situations, motorcycle trailers are not required to have separate trailer brakes, provided the weight being towed does not exceed 1500 pounds. The California Department of Motor Vehicles suggests that if you do install brakes on a motorcycle trailer, you should ensure that the brakes do not brake harder than the motorcycle brakes. An inequality in braking power can cause the motorcycle to flip backward when the brakes are applied and send it over the trailer. Motorcycle trailer brakes should be adjusted properly at all times.
do you believe that.. flip "backward" when brakes are applied???and "send it over the trailer"??? I am not making that stuff up... some really creative engineers in on that one.... (Maybe there are some trailers attached high on the sissy bars)
Edit: And after a little thinking, I can come up with a scenario... if the trailer load that you are pulling has a HIGH center of gravity, applying brakes will greatly increase the tounge load so that the bike front might get light or even leave the ground.. maybe if you hit the brakes hard enough, it would flip like hitting a spoon or fork on a table... still a bit far fetched..
