remove mirrors (for your first time, remove them then you will see that you only need to remove one bolt and lose the other) - pull the rubber to show the bolts
with mirrors off, put a flat screwdriver wrapped in a rag between the headlamp and the windshield trim and pop it up.
take the trim off and you will see 4 philips bolts holding the windshield.
