Part of the problem I'm having was posted in a different thread, but that's been fixed so I started this one.
History: Dogbone fuse blew and I finally began the process of replacing the starter solenoid as the wires were all but burned through. Got one from eBay, and that was a mistake. It was shoddy. And here's a possible hint to my troubles--for no more than one second I touched the wrong wires to the wrong place on the solenoid and I saw a very quick puff of smoke from under the seat.
I eventually ordered and installed a Honda replacement solenoid. Battery tested no good. Replaced it. Hooked everything up and hit the starter button...nothing. Neutral light glows. When I cross the poles on the solenoid the engine turns over well but will not start. Doesn't even act like it's trying. I have fuel in it.
I found that the ignition fuse was blown. Replaced it but it blows the instant the starter button is pushed.
So I'm here with the experts. Help me, somebody, cause I am losing some prime ride time!!!
Thank you!!
Thank you!!
