I really doubt you have a timing issue. It sounds like you have a bad coil. Mine had the exact same problems. A new coil fixed it.
Hope this helps.
Hope this helps.
I don't think the cdi is that sophisticated.Thanks glhonda!
But what if ported vacuum signal is incorrect?
It isn't going to be a pulse generator if only one cylinder is affected.so I will check coils, cdi and pulse generator. There are no more items to check.
Let's imagine (in theory) that "some bug" makes ignition timing "late" at high rpm only. What kind of bug could it be?The pulse generator send a signal to the cdi to fire the coil at the right time. This is a wasted spark system (two plugs firing off the same coil at the same time). The pg's and the cdi are doing their job correctly, since it doesn't affect the other cylinder fired by that coil.
Hi,I'm troubled by the "white grey" mixture on the plugs. That to me is an over lean condition. Which would also explain why you can't get any top end speed. It is starving for fuel.
I would do the fuel delivery test in the Factory Service Manual to make sure your pump is putting out enough fuel. I would also change the fuel filter to make sure you don't have a clogged filter.
