the po conected the accesory plug to a hot wire connected to the ignition switch, i would like to move it to the acc key or direct. if i wire it into the fuse box which fuse would be best? what amp is recomended? if i go direct where is the best place to tie in?
the reason is so i can power adapter for music while cleaning or working on bike with all lights and all on to drain battery.
it's on a 85 ltd 1200.
Discussion Starter · #2 ·
tried to edit couldnt make it work last line should say so lights arent on to drain battery.
2000 GL1500SE
Look under the top cover at the fuse holder. One of them is for accesories and has a - and + screw terminal for connecting some wires for your plug. I think the fuse is a 10amp and should be enough for what you want to use it for.
