When I purchased thie 85 LE the high beam was burnt out. Would idle fine. A couple of days later the low beam popped.
Bought a new bulb today, bike was running as I was installing the bulb. Plugged it in and the bike died.
High or Low beam, will not idle. Will run fine if holding the accelerator.
Fully charged battery, bike is charging.
The only thing I have touched electrically was before I changed the bulb I ran a ground cable from one of the bolts on the rectifier to the frame. A couple of times while at high RPM's the volt meter next to the stereo showed 16.0 +
And I found a couple of post saying check grouind, so I made sure surfaces were clean and added a cable to just one bolt.
Bike idled fine after the ground before installing the bulb.
Also, where is this 5amp fuse that is supposed to be under the left pocket? I cannot find a place for it. But there is a little pocket with a spare 5 amp.
Thanks!
Thanks!
