Couldn't go out and ride..So may as well do some work on the bike..so I decided to add some more light to the front of the Wing. Added LED strips in the turnsignal/running light on the front..mainly as running lights...looks a lot brighter to me!!
Did you have to crack open the lens box ? Are they just running lights ?
I did crack open the lenses and added a strip of LED's in all four of the lens boxes. Just used a heat gun to warm up the adhesive and GENTLY pried open. Added about an 8 led strip to each. Then reheated the glue(?) and reattached also added a dab of hot glue to be safe! And yes just running lights.
Thanks for the info.
You can NEVER have to many lights !
Have to agree with that statement...visability plus! Saw your changes to turning /running lights...that may be next..I still have the original bulbs on mine. Pulled them years ago and soldered the two filament leads together on the buldb base and had doulbed the brightness..not sure why Mother Honda used that bulb!
