1 - 20 of 21 Posts
Everything started just as: i'll try to do the belts.... and then...
-changed engine oil
-final trans. oil
-distr. belts
-changed cooling in the all system and checked the all rubber connetors
-emptied clutch system and new oil
-emptied the front and back brake system and new oil
-sub filter and cruise filter done and also checked for everything next to
-compensator exhaust: connectors remade in in stainless steel due to heavy rust.
-cleaned the pipes iside
-lamp holder for position light changed
-alternator redone entirely from berings to....
-installed superbrace
- w15 new oil on the forks
-sobstituted position lights with led white lights
-brand new bixeno on the front
-side orange lights
-stop light in the lower back
-side lugagge lights
-progr. srpings in the front
-progressive 416 in the back
-led front lower masck
-led lower fin
-led side air intake
-led on the passenger pegs and lower part of it
-led on the upper side lugagges
-led on the radiator
-led below the mirrors
-brand new gel battery
-reviwed back gear and cables....same as throttle...
64.000 km
soon ....metal cast from duplicolor on the rims..and final trans.
-air dries compr. to be taken off and dry the little bearings inside
-more led on the back....
-new windshield for spring time
seafoam engine cleaning...poured 160ml in the oil engine and also in the gasoline.
honestly i tough that being the clutch in the same oil wasn't a good idea but so far....so good.
ok now the bikes runs much better, smother and seams almost lighter! :)
whoooo boy what a job! hard...i am not a mecchanic and i am not used to this hahaha.
Good job!:waving:
HAY--- you been a busy little beaver-- HUH. looks good.
Lots of lights on that machine - looks great!! :applause:
::bow: Pippomaranga, lookin really gooooodd!!
Good job!
You're doing Exactly the right thing, when getting a used bike... Every hour you've put into it so far, will pay you back in terms of having a reliable bike.
Sharp looking machine, well done!
Anyone would think xmas is coming.
Discussion Starter #10
sorry for the ugly pic....new pictures much better done in my album to be seen.
thanks you all for the comments.
Answer Seeker & Kibitzer
ALEX BERECZKY wrote:
Good job!
Agreed ! Having a baseline starting position for maintenance records will pay dividends in the long haul...and you have th eassurance that it was done to the best of ones ability!
If a cager can't see that baby coming, they're either stoned or blind!! Nice bike!!! jimsjinx
Lost on this *****
That is some great work. You treat it well, and it will treat you GREAT!!
But you said you added Seafoam to the oil. You don't plan on leaving it in there ,,,do you???
Discussion Starter #14
Well seafoam as far as i know should dissolve it'self after sometime.. But in any case i will drive another few hours only and will change oil again.
Discussion Starter #16
Whuo whuo whuo....hold on!:
Not even 200 km with brand new oil and about 80+ with seafoam and i drained the oil that was darkish green very very dark and wayyyyy to much thin and liquid!
Seafoam made the oil to much thin to fast!! And thanks god i looked in to it soon! What the hell... And thanks god that i got a mail from a seafoam tech that told me that was ok....
Bottom line: yes it of course cleaned the engine but it killed the all new oil after 50 miles!
Wow, I hope I have the courage you did to try some of that stuff. Just ordered some Gates timing belts but hope when they arrive I'm not too scared to try to replace them!
Discussion Starter #19
Fallow the instruction by the letter! Read it before 20 times and once you will do the job, take pictures with you phone on how and where signs are, pick ups exc exc take a lot of time , all you need! Just do it rigth and apply the rule of the dry test! Sparks out and 5 turns of the engine manually.... 5 mm of tension on the belts. All wiLl be fine.
Lost on this *****
Follow this tutorial that "Rudy" had put together,, and you'll do the job like a pro :thumbsup:
http://goldwingtech.info/timingbelts/timingbelts.htm
1 - 20 of 21 Posts
