1 - 20 of 34 Posts
Hi everyone!:waving:
I am continueing to search, but I'm sure I saw a good proceedure here somewhere on how to test for a bad alternator.
I have checked at the batery and do not have any voltage increase when the bike is started. Thought I'd test directly at the alternator so I know if that is the problem, as I suspect, or the connections from alternator to battery.
Didn't the forum used to have a A-Z of technical problems section? Maybe I'm blind but can't find that.....:?
Thanks!
Andy
The A to Z is gone for good I guess. Check the voltage at the main lug on the alternator and at both ends of the dogbone fuse to the right of the battery.
Thanks.
Voltage at the main lug on alternator stays at battery voltage with bike running and checked I have 12V on the green wire feeding into alternator. So next step is to pull the alternator and see if cleaning works or brushes are stuck. Found another thread that had that so hoping for the quick/easy/cheap fix!
It aint rocket science
Yup. The A-Z forum had hundreds of excellent How To's and is how during a web search first brought me to this site.
Well, took the alternator off and checked the brushes. They look OK and I cleaned them to make sure they can move freely.
Also checked the slip rings and they meter correctly.
Didn't test stator as it required unsoldering and I figured I'd try the cleaning first. No specific tests in the manual for the voltage regulator.
So I threw it back together and..... still no output.
Condenser I wasn't sure of. The manual was a little ambiguous as to the testing. Maybe an issue.
So now I'll need to decide if I pull it and test the stator or admit defeat and order in an alternator. Can you buy just a stator or voltage regulator for these and any idea how much? :?
Alternator complete = 243$ , stator = 69$ , rectifier = 135$ , all from hdlparts .
But first locate your problem , eventually take your alternator to a local repair shop , and have it tested .
Discussion Starter · #12 ·
Well, removed it again and un-soldered the stator. Meters out ok; minimal resistance between leads (.3 ohm) and no continuity to the core.
If I've checked all else, does this mean by process of elimination it must be the regulator?:?
Discussion Starter · #13 ·
Well, not having any luck finding someone to test the regulator. As soon as they hear motorcycle they don't want to do it as they say they don't know how to hook it up.
You could try calling these folks for some test ideas, or maybe find out that you can't test it yourself. Either way, looks like they are familiar, intimately, with GL1500 alternators.
http://myplace.frontier.com/~hemi-roid/
I have never even seen a alternator on a 1500. But it can't work too much differently than any other internally regulated alternator.
Field voltage is supplied through one brush, ground is supplied by the regulator on the other. Both brushes are insulated from the case.
The GM alternators use to have a slot in the back of the case known as the "D" slot, because it looked like a "D".........
By going through the slot with a paper clip, you could ground the second brush, full fielding the alternator, and confirming the regulator good or bad.
Anything like that on the 1500? Stock, or Compufire?
Junior Grue
What you have is a car alternator that mounts a little different and has a drive flange instead of a pulley.
Take it into a shop and let them look at it. They'll have to remove the flange and put on a pulley but from there it's just standard testing.
Discussion Starter · #17 ·
Thanks guys!
I found a shop that is certified for doing rebuilds and the tech there said no problem testing the regulator. (For Ken Bergen who is "local" it is in North Van) I took the whole thing in but since I had unsoldered the stator to isolate the leads left it that way so he has easy access to the rectifier. Should know tomorrow morning.
Just wanted to say the stock alternator doesn't charge untill the RPM's reach about 1500 did you just let it idle or did you rev it up. This is one of the reasons that people such as me buy and install compufire and other types of inhanced alternators. They are charging at Idle not 1500 to 2000 rpm. its so bad that sometimes people who are stuck in traffic for a long period end up with a dead bike as the whole time they sit there the are running off the battery not the alternator.
Discussion Starter · #19 ·
Yeah, tested both at idle and 2K RPM. Thanks.
Tech tested and did find a bad voltage regulator. I'll have it back by 5 today and on the bike tonight.:thumbsup:
Most of the time it is just a voltage regulator on charging issues. The question is.
Do you want to take the alt. apart on the side of the road and do all the checks or just install another and fix it later?
As for myself. Get me going and I will/can fix it later. But sometimes it would cost more to fix the alt. than to buy another one (more than just regulator problem).
In other words. It depends on how much down time you are willing to do/take in order to ride again. I found an alt. with a bad regulator I am going to fix and keep in bike just because I like to take long trips.
1 - 20 of 34 Posts
