1 - 2 of 2 Posts
hi ! i have a bad idle on my 1500 when it is cold.
i put my choke on when i start the bike and it seems to be running on 4 or 5 cylindres, i have tried draining the tubes and changing the plugs.
it works well when it is over 15 degres celcius but as soon as it drops under 15 celcius the motor doesnt run well
Busdriver
When did you last change your air filter?
Do you use full choke when you start cold, or half?
Try both ways and see if any diff.
I would also inspect the air temp sensor located inside the air box, left side, as well as the operation of the cold/warm air valve or heat riser in the small detachable plastic piece that is attached to the front end of the air box. Pay attention to all vacuum lines and any wiring.
1 - 2 of 2 Posts
