1 - 20 of 47 Posts
I have 2 1999 GL1500's, one is a stock SE, the other is an Aspencade/Motortrike conversion. The problem I am having is with the SE. I find that everytime I let the bike sit a few weeks the battery will be discharged low enough to be unable to turn the engine over. This battery is about 18 months old. I have had to add water to it twice and have charged it each time that it was dead.
I checked the voltage across the terminals of the battery at 1500 RPM, it read 14.3 volts. Then I checked for the "switch off" amp to see if I had a parisite voltage draw. From negative terminal to negative cable I am reading 2.37 mA. The battery has 12.65 volts with key off.
In comparing the 2 Wings I find they are both have similar readings. Both are pretty much stock with no extra lights and such. Both have power point/cig lighters.
This hasbeen the second battery to give me the same trouble, but I don't see any alarms in the voltage or current readings. Help, this thing is driving me MADDD!
Monkey with a Football
Those are normal readings.
The max draw spec is 5 ma so you are well within that.
The draw is for the clock and the radio's station memory settings. It is a keep-alive circuit that Honda calls the Backup.
With my bike sitting I will go give it a few hour 4 amp charge every 3 weeks if it has been sitting. This keeps it above the difficult starting is avoided. This is with a good battery as well. If the battery is older, you may not get the 3 weeks that I do.
BTW to see if you have other parasitic draws or if you just want to kill the Backup draw, you can pull the Backup fuse in your fuse block.
Switch batteries and see if it happens to the SE or the trike.
Do you have a stock alternator, or a Compufire in the S.E. along with the wet cell battery?
gumbyred
Thanks for the replies. The alternator is stock on both Wings. They both are wet batteries. I don't know why i didn't think of swapping batteries between the two... must be "old timers' kicking in again.
If I let my bike sit for two weeks I can't start it.
Normally I run it about 4 or 5 times a week, but this time of year if we get a bad spell of weather two weeks isn't out of the question to leave it parked. So if there's any doubt in my mind, I plug in the battery tender.
I have a 96 se.
2000 GL1500SE
It doesn't sound like your battery should be pulled down with that little current draw. However I would put it on a battery tender if I was going to let it sit for over a week or so just as a standard procedure. That is what I do and my battery is always ready to turn the motor over fast when I do get ready to ride it. The battery will last longer if it is kept charged and not let it get in a run down condition.
I had the same issues with my 99SE battery.
1. You must get yourself a float charger for when you are not using the bike.
Mine was eating a battery every few months to a year (not enought riding in the NW) the float charger stopped the problem.
This is the one I use.
http://www.harborfreight.com/automatic-battery-float-charger-42292.html
2. Ride your bike more often and it will not present a problem.
Active Member
THATS THE ONE I HAVE...WORKS GREAT....CHECK THE STORE FLIERS I THINK IT'S ON SALE FOR 4.99 OR 6.99....RIGHT NOW...
REMEMBER IT'S NOT FOR CHARGING...JUST MAINTAINING
Hey Rudy!
Which ones the "backup" fuse?
T.
tnoort wrote:
Hey Rudy!
T.
It should be Fuse 9 (5 amp) in your fuse/relay block or under the left fairing pocket depending on year model.
Something just draws those bikes down. I have owned 3 1500's. 1990 1996 & 1999. Guess what I always have had drain problem with the 99 and yes it is an SE if that makes a difference.
I work at a large RV dealership and campers do the same thing. 1 model will drain a battery in a week. Others can sit for a month and the lights work.
If you are not riding the bike every week. Use a tender jr on it.
Token Canuk
I keep a Tender plugged into one of my cig lighter sockets, works fine. :waving:
When you replace the batteries, put in gel/AGM batteries and they they will hold up longer.
Try disconnecting the battery for the same period (after a full charge) and then test the battery voltage with a test meter. That will tell you if you battery is failing, or pull it and take it to Autozone or Kragens and have them load test it.
Have you replaced the brushes in the alternators yet? They are a factor if you want your battery to charge while driving. (sitting running at idle won't charge the battery)
The stock alternators were a weak point on the 99's, so keep them fresh with planned cleanings and brush replacements, end bushings also.
I ran into problems with my alternator yesterday. Voltage on battery at 1500RPM was 11.45 and at 3000RPM it showed 11.93. I was kinda set on just getting a compufire, do you suggest new brushes will get it up and running again? I will eventually go with a compufire due to the planned upgrades, but right around x-mas I could live without the $360,- ticket...
A good cleaning, brushes and bushings well get you back up and running. You can do it or take it to a local automotive alternator rebuilder. If you do a search there are cross reference numbers to get at an auto parts store.
Merry Christmas
:waving:
i use a small solar panel charger and hook it up when a bike sets . i have been doing this for years on sail boats, it works. regards walkabout :smiler:
Thanks for posting all the refs. Looks like I can get away with a clean up job due to my low mileage, however, I am still leaning towards a compufire....
1 - 20 of 47 Posts
