sounds like a vacuum leak.
all responses to this question are to be placed in your original thread, please try to keep it all in one place so that folks will know what you have received advice on. Adding onto the bottom of a very old thread (5 years now) does not draw anyone to your problem. Most folks will skip the thread because they have seen it already.My 88 GL1500 run ruff but with the choke on it run good. Put new plugs checked the timing belts and compression all good line up with all marks. This happen when I down shifted to first gear and cracked the throttle open, what i think was to far because afterward the bike started running bad. But again with the chock on it run good. Now what did I do??????????????. and anyone help me with this problem??????????????????
