I had a small pyramid equalizerbooster with 3.75 - 4.0 inchPioneerspeakers. My back speakers are a pair removable6x9 pioneers boxed on top of the trunk lid.
The equalizersucked sinceI could not get the motor ignition whine out . Noise suppression capacitors and verified grounds did not correct the problem.
I just trashed the system and replaced them witholder bose speakers. Some older Corvettes and Cadillacs had small ~4-4.25 inch front speakers. Each speaker had its own amp and the front amps are in the front fairing with the speakers. 6x9 with amp in my box. I did not have to enlarge the existing fairing holes, but I did do some minor internalmods to the dash cover for clearance. Much better sound than before.
But, here is my new problem. With the stock radio, I have a constant low frequency buzz/hisss. Not the high pitch engine ignition rpm whine noise.The constant buzz is a little loud with the amps powered up. I have very little volume control. So, the only way to get rid of the buzz is to turn the radio off or crank up the music. With the radio on and volume low/off, there is no music but a constant buzz. Two/three clicks on the detent volume control and it is already loud. The only way to get rid of the buzz is to give her about two/three more clicksandshe is jammingmasking the buzz.But, it is loud. Sound is maxed out at half - 12 o-clock straight up on the volume control.
The buzz is like a florescent bulb transformer but louder. The buzz is constant and buzz does not get louder with increased volume control. It is just there.
Any ideas on whatcould be done to reducethe buzz/hissss?
