1 - 3 of 3 Posts
I was riding, :waving:everything great until I used the reverse lever and the bike shut down.:sadguy: I can not get a reverse or neutral light. I can push start the bike, all gears and neutral OK but no neutral light. :wtf:I am guessing the switches either neutral or reverse switch or both 1996 bGL1500 with 70K miles.
Other side of the pond
There are a lot of existing threads on this problem. The usual suspect is the micro switch beside the reverse lever cam, under the left panel.
killer driller
try cleaning your reverse switch,there should be a small hole underneath the switch you can spray contact cleaner into,work the switch back and forth several times spraying liberaly
1 - 3 of 3 Posts
