All going well, engine back in. One small problem is that I can't work out where one of the carb pipes goes. Looking down and forward, there is a thin black pipe with red tape. It has a T piece and one end is blanked off. Where does the other end go? Its on the right of the carb
Rob, I don't own a 1500 but most bike have a vac. lines routessticker under the seat,rear fender, or side covers. I'm sure I'm of little help here.
If you can put up a pic. it may help. I'm sure one of the other guys will know what it is and where it goes.
Kurt
Thanks Kurt, will check seat when I get home. Did try pic but will have to reduce size of file
