Yes, and yes.
There is a spacer that lets the clamp be tightened just so much. You can install new boots, or file the spacer.
BTW: The upper clamps are the similar and might have play unless you do the same with them.
Bill
Yes, and yes.I have my carbs off. On that rubber piece that goes between the carbs and intake I can wiggle it back and forth a tiny bit even though the bottom clamp is as tight as I can get it. Both sides are the same. Is that normal or a problem?
Thanks.
Or you could read ALL the replies to this thread.....I suppose the right thing to do is to order 4 new clamps and 2 new insulators and just replace everything?
What the heck does that mean? I'm not blind and I read every reply multiple times.Or you could read ALL the replies to this thread.
Bill
