You are probably not reading the manual right, you don't need to remove the tank to synch the carbs but you need to remove the lower fairing panels (so you can get a long screwdriver to the synch screw on the right and to connect the vacuum gauges both sides). You don't even need to remove the petrol tank to take out the carbs completely! You also don't have to remove the DUMMY (FALSE) tank panels either, just in case the dealer says you do.
