1 - 3 of 3 Posts
Ciao a tutti,
I need to buy the handlebar controls for a cb on a GL1500 SE. I saw 2 versions, one smaller (for Int. or Asp. I suppose) and one larger (the one I need). If I buy the smaller may I take off the switches and put them into my lower part of the control? I discover under the adhesive there is an existing hole for the channels switch .
Thanks in advance
Andrea
yes
Hi , received the switches I begun to install them. I found no problems, as you said I had only to unscrew the switches from the different control unit. But there is non space to route the new cable. Have I to drill a new hole into my audio control unit?
ANdrea
1 - 3 of 3 Posts
