My 88 has been gradually getting worse since i bought it 6yrs ago at 67k miles and now it has 103k. I tried Castrol and it was okay. I tried Amsoil 10w40 this summer and it was okay too.I did the preload the shift lever asecond before the actual shift and that helps. I finally changed to the Delo and my Wing does not like it. I sure hoped it would at less than $12 a gallon.I am not sure whatoil i want to try next. Niehaus cycle said not to use 20w50 when i mentionedusing it.I used Supertech 20w50once this summer and thought it did pretty good I don't have the 4th gear jump out problem and just wonderinghow long it will be until i do if ever.
Anyone have any thoughts on that?????????
I rebuilt the slaveabout 4yrs ago because it was leaking.
No slop in the clutch lever since i replaced the bushing and rod. I just flushed and bled the hydraulic and am still getting used to having to let the clutch lever out farthe...... soit is releasing the clutch alittle more than it did. I was hoping that would helpwith the clunky shiftingUP and really bad DOWN.
Just did the nightmare coolant hoses and orings and thermostatthis spring and i have 2 tires to put on this winter and other maintenance.
Iam having expensive thoughts of trading in for a 2012 while mine is still working. Who needs retirement money anyhow?
