Hello everyone
I own a 1999 GL1500SE goldwing with 185,000km(110,000miles),a week ago the clutch started slipping,the bike would not begin to move until the clutch lever was almost all the way out,I replaced all the dot4 brake fluid in the clutch and resevoir and it was good for a couple days,now it seems to work good when first starting out untill the engine is up to operating temperature and then it will not start engaging till the clutch lever is almost fully out,once the bike is warmed up.Onced the bike is at operating temperature the clutch will slip when you accelerate hard.
Is my clutch in need of repair/replacement or could I have air in the system,I understand there is no adjustment...as it is a hydraulic clutch.
Can anyone give me some advice or is it just time to replace the clutch?
**When I replaced the dot4 brake fluid I used dot4 synthetic brake fluid**
Thanks everyone
Hello everyone
Thanks everyone
