hi andhappy new year to all.help needed to bleed new fluid in the clutch system on my 1989 1500gl. is the correct way to get a jar put in some dot 4 connect a peice of tube to the bleed nipple place tube into the jar open bleed nipple and work clutch lever untill new fluid comes through topping up the resevoir as i work the lever. i have been told doing this way stops air entering the system and you dont have to keep opening and closing the bleed nipple. thanks for any help or pictures on this subject.:?thank you once again for all the info you have supplied in the past and hopfuly in the future dave(uk)
