Hi,
Can you please advise me on an incedent that occur whilst I was traveling home.
I approached a junction and as normal pulled the clutch lever in only too hear a sound that sounded like metal being drop into a metal tray, on releaseing the lever it went but on revving the engine a tad it came back.
Needless to say I have not used it since, has anyone any ideas please.
Nick.
02 GL1800 w/Auto Pilot
I have never worked on the clutch for a 1500 but what you describe does not sound good.
My suspicions are that you will be doing a clutch rebuild, or it could be a bad UJ (universal joint).
There should be a 1500 clutch guru along shortly to be more helpful.
you dropped your bottle of beer mate!!....;)make a bunch of checks...driveline...rearend....change in the bags!!.....if all checks out ride it gently and ....it rides??...run it on centerstand and click through the gears with a little throttle as usual...with wheel spinning...if your afraid of it locking up!!...and keep testing it to see more symtoms...you get all the gears?...yes check for oil bits...good luck!!...keep us updated.
Hi thanks for the info methinks a pickup too the garage is in order dont want to knacker it up, will let you know the outcome.:waving:
Hi actually its only been out of the garage about a month after having its service plus M.O.T. (u need this to ride lawfully on U.K. roads
