1 - 20 of 21 Posts
Happy Thanksgiving All!
Well, its been 4 weeks to the day that I broke my ankle. Two more weeks and the cast comes off. I still want to get back on the road before the season definitely ends.
The 1500 is still new to me so not sure what the cold weather brings. Our lows to date have been high 20s to low 30s. Every 5-7 days I go out and start the bike. When cold, it has been very tough to start. I've experimented with full choke to no choke and all in between. Gas still has some Seafoam in it. Battery Tender Jr. connected constantly so battery is not an issue.
Is tough cold starting the norm for this bike? Any hints or suggestions appreciated. Thanks!
psu
mr irrelevant
Last winter i tried several different methods when temps below 32 to start the bike....If it was sitting for more than a wk, i found that twisting the throttle once bout half way, then back to off, put choke on half or little more and hit switch in 3 sec intervals....usually fires up within first couple tries, then adjust choke up a little ..Hope this helps...
I would always start with full choke and NO THROTTLE on a new bike. Then try full choke and only about 1/4 throttle if first doesn't work.
Full choke , no gas - if that dosnt work your battery may be weak (a weak battery can spin the engine wel , but there is not enough power to produce sparks on the plugs ).
Monkey with a Football
^^^ This fellow has it right.
no problems except one morning it was 23 degrees out and it took a little longer to get started but not very much..just choke only. Now my 82 1100 i would put a lamp under the bike with the battery tender an it would start even at 14 degrees:action:
Do they sell block heaters for Wings ?
I really dont know for bikes. I know they make them to go inline on heater hoses on autos and they also make heated dipsticks for cars maybe can be modified. Really something to think about though:baffled:
You could always mount an electric hot pad under the engine sandwiched between it and the top of a belly pan for winter use.
Most all of the GL engines are nice and flat under there.
Just go plug it in an hour before departure and you should see a great difference.
If you have old spark plugs, or have no idea how many miles your plugs have on them, I would change them before it gets cold. New plugs make the 1500 SO much easier to start in the spring, or the occasional day when the weather cooperates.
Gumbyred
Discussion Starter #12
A lot of great ideas here. Thanks again for all of the input.
psu
If mine has been sitting for a week or more this is the way it goes:
Choke about 3/4 closed, give the throttle a couple of twists to throw some gas down the carbs, then no throttle. Be sure the kill switch is in "Run" and hit the start button. Usually fires right up... then adjust the choke as needed to keep the rpms about 1500-2000 while she warms up.
Just my method - not so cold in the UK (yet ?). Short bursts on the starter button. Don't keep it turning over contiuously as mine starts when I RELEASE the starter button. Makes sense as all power then goes to the plugs, etc and not the starter. IMHO
No throttle, just full choke.
Let us know when you have found your right method.
The twisting the throutle a few times sounds like the ticket.That will put some raw fuel in the intake and give it what it wants. A cold engine wants a rich fuel mixture.
mr irrelevant
I could of sworn i mentioned twisting the throttle earlier...LOL...it definately helps...
I know you posted about it earlier. I just didn't say that you hit the nail on the head. LOL:bow:It's all good! :sleepy:
batt on its way out
How about one of those 300 W magnetic heaters. I should stick to the oil drain plug and the heat would go up into the crankcase.
1 - 20 of 21 Posts
